Discussion topic: SKY Q MIni but have give bb password each time
Message posted on 18 Oct 2023 06:16 PM
Hi
Just got tv installed at brother's house and SkyQ mini in the room he has the main box in the sitting room
But I have to enter my brother broadband password each time I log in to the tv
Please advise why and what to do to stop this
TIA
Message posted on 18 Oct 2023 06:30 PM
Re: SKY Q MIni but have give bb password each time
@Aayush2010 wrote:
Hi
TIA
Hi @Aayush2010
Not sure if you are referring to the main Q box or the mini.
Minis need to connect by WPS to main Q box or Sky router if nearer and yo are on Sky broadband.
Message posted on 18 Oct 2023 06:38 PM
referring to mini Q box as brother, not with sky bb his router in downstairs in the sitting room
Message posted on 18 Oct 2023 06:43 PM
Hi @Aayush2010
Then you must connect the mini by WPS with the main Q box.
Carry out a Network Reset on the mini.
Message posted on 18 Oct 2023 06:48 PM
hi
thanks why is this issue as t additional box nothing else
but he not with Sky Bb Re Boster
as it is a bit silly doing this each time need to watch sky plus if need to give box back it to late thus watch nextflix or prime on tv
Message posted on 18 Oct 2023 06:52 PM
error msg i saw earler was MR102
Message posted on 18 Oct 2023 07:30 PM
@Aayush2010 wrote:
hi
Hi @Aayush2010
Mini boxes do not connect by WiFi to non Sky Broadband .
They will only connect to a Sky Q main Q box or a Q WiFi Booster.
Have you tried to connect it to the main Q box by WPS exactly as explained in my earlier post?
If the box will not connect you can use a Q WiFi booster positioned between the main Q box and the mini. You connect the main Q box to the Booster by WPS and then connect the mini to the Booster by WPS following a Network reset.
Sky will supply Q WiFi boosters free of charge to aid Sky Q connectivity.
You don't need to be on Sky Broadband to use a Q WiFi Booster.
MR 102 is a message that tells you the mini cannot connect to the main Q box.
Message posted on 19 Oct 2023 06:40 PM
Re the last reply now been advised need an engineer to come and see what the issue is and thus charge for the engineer to come at weekend as i work uring the week
when the brother who placed the order was advised not to need an engineer
does anyone at sky know what they are talking about
Message posted on 19 Oct 2023 06:52 PM
Hi @Aayush2010
Normally there is always the option to self install mini boxes.
However you have difficulties with the technical side then it is best to get an Engineer
