Discussion topic: Reset my pin
Message posted on 03 Mar 2023 09:57 PM
Reset my pin
Hi there,
I need help resetting my tv pin as i have forgotten it.
Message posted on 03 Mar 2023 10:00 PM - last edited: 03 Mar 2023 10:01 PM
Re: Reset my pin
@GaryDanielle wrote:
Hi there,
You can do this in your Q box.
Go to the home menu and scroll down to My Sky.
You will see an option to reset your Pin
Message posted on 05 May 2024 06:27 PM
Re: Reset my pin
I am visiting my elderly mother who has sky.
she is unable to watch movies because she has forgotten her PIN
please can anyone help with this.
i will try to reset pin, but she dosent have any of her passwords etc
Message posted on 05 May 2024 06:36 PM - last edited: 05 May 2024 06:38 PM
Re: Reset my pin
Unless it's been changed previously it's usually the last four digits of the viewing card. She can find it on the box via Home - Settings - System info.
Message posted on 05 May 2024 10:07 PM
Re: Reset my pin
she is unable to watch movies because she has forgotten her PINplease can anyone help with this.
@Nadine1970 the pin number is normally the last 4 digits of her viewing card number this can be found by pressing home scrolling downt to settings then system info
Try changing it to something like 1111
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
