Discussion topic: Pulsing blue light and steady red light
Message posted on 05 May 2024 12:11 PM
None of the reset procedures work. This is the fifth time in a week we've woken up to this, previously resets have worked but this time nothing. Is it time for a new box (only had it a few months).
Message posted on 05 May 2024 01:52 PM
Re: Pulsing blue light and steady red light
Hi @Tenesmus
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
Message posted on 05 May 2024 05:32 PM
Thanks @oldfella I had aleady tried that. Standby mode is set to None. It usually happens during the night.
I had another go at pressing standby and unplugging and this time it worked (after six attempts failed). Do you know if it's a software or hardware issue? It's very annoying, especially as I like to get the TV news in bed in the morning and the mini box says it can't connect to the Q box. Again.
Message posted on 05 May 2024 05:56 PM
There is far more than ECO mode in the link I posted @Tenesmus
If you have been completely through the link it does lead to a conclusion if you cannot solve your issue
Message posted on 05 May 2024 10:55 PM
I tried reset multiple times and recovery hold-the-button-in-and-plug-in simply didn't respond (I managed to get that to work last week, but not this time). However, as mentioned, the reset finally worked.
The resolution appears to be Get A New Box. What will the new box have that the existing one doesn't? Different hardware? Different firmware?
