Discussion topic: Remote
Message posted on 29 May 2025 06:42 PM
							Remote
My sky Q remote isn't working. I've tried everything
Message posted on 29 May 2025 06:48 PM
							Re: Remote
Hi @Vikki12
Failing this
Check the following link and it will lead to a form for a replacement remote.
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment
In the meantime if you have an Apple device with Sky Go you can set up a virtual remote to control your Q boxes.
See following link.
https://helpforum.sky.com/t5/Sky-TV/Virtual-Sky-Q-Remote-Now-Available-on-Sky-Go/ba-p/4363637?
Message posted on 03 Jun 2025 09:09 PM
							Re: Remote
Thankyou so much for your help. I did everything I could & it wouldn't work.
I applied for a new remote control. It said it would be 3-5 working days. It arrived the morning after, I was very happy.
Thankyou again.
