Discussion topic: Ireland: sky q box keeps crashing. Need to reboot to get channels and apps
Message posted on 03 Jun 2025 09:00 PM
For the past fortnight or so, certain apps haven't been working (Paramount+ yesterday), and the tv has been blank when I turned it on or flipped back from an app. We did get a text from Sky a while back apologising for some kind of update error that caused problems. Now it seems to be happening again. I've had to reboot twice tonight.
Message posted on 03 Jun 2025 09:04 PM
Re: Ireland: sky q box keeps crashing. Need to reboot to get channels and apps
Hi @AG59
Try a Reset Settings in the main Q box hidden menu.
Message posted on 03 Jun 2025 09:08 PM
Cheers for replying so quickly, and for the instructions on how to do it. I'll give it try tomorrow - teenagers currently watching something, and if I interfere with that I'll end up buried in the garden...
