Discussion topic: Remote doesn’t work unless very close to the sky box
Message posted on 18 Jul 2023 08:07 PM
Our sky remote doesn't work unless really close to the sky box .. we have changed the remote with our spare and it still won't work
Message posted on 18 Jul 2023 08:20 PM
Re: Remote doesn’t work unless very close to the sky box
Have you tried rebooting the Q box ie
Message posted on 18 Jul 2023 08:27 PM - last edited: 18 Jul 2023 08:27 PM
Hi @SCG80
If it is a Bluetooth remote (one with a Voice control microphone button) then make sure it is correctly paired to the Q box.
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Message posted on 18 Jul 2023 08:32 PM
Thank you but no that hasn't worked and I've just noticed the volume buttons don't work at all
