Discussion topic: Remote doesn’t work unless very close to the sky box
This message was authored by: SCG80
Our sky remote doesn't work unless really close to the sky box .. we have changed the remote with our spare and it still won't work
Re: Remote doesn’t work unless very close to the sky box
Have you tried rebooting the Q box ie
LG 49SJ 810 V UHD TV, Google Pixel 10 Pro XL mobile
Hi @SCG80
If it is a Bluetooth remote (one with a Voice control microphone button) then make sure it is correctly paired to the Q box.
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Avatar for SCG80
Thank you but no that hasn't worked and I've just noticed the volume buttons don't work at all
