Discussion topic: Q remote has connected to glass
Message posted on 07 Mar 2025 09:24 PM
I've switched back to sky q I've set the box up but the remote has linked straight to sky glass now I can't access sky q because remote controls tv and not the q box
Message posted on 07 Mar 2025 09:28 PM
Re: Q remote has connected to glass
Try repairing your remote again;
- Hold 1 and 3 together until the red light flashes 4 times.
- Select Continue and enter the brand of your TV.
- Select Find it for me.
- Press the volume buttons on your Sky Q remote and see if this changes your TV's volume.
- If it doesn't work, select No, try another until you find the right setting.
- If you have a Sky Soundbox or speaker system, select Yes and follow the instructions or No to finish setup.
- Select Finish.
More in using Sky Q with a Sky Glass TV here;
https://www.sky.com/help/articles/connect-q-to-glass
Hi @Pauly1
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair to glass TV
Message posted on 07 Mar 2025 09:42 PM
Thanks so much fpr the help,I can now view sky Q but any idea how I can use remote for volume or do,I now need 2 remotes
Message posted on 07 Mar 2025 10:04 PM
hi @Pauly1
In the remote pairing process you should be able to pair the remote to the glass TV to control power on/off and volume..
Glass Television should be in the pairing options.
