Discussion topic: Q box remote doesn’t recognise new tv
Message posted on 30 Nov 2023 06:48 PM
I have just set up a JVC LT-40CR330 TV .
this model is not in the list to pair the Q box remote control.
I have the code required but don't know where to enter it.
any ideas?
Message posted on 30 Nov 2023 06:54 PM
Re: Q box remote doesn’t recognise new tv
any ideas?
Hi @Heath1
Afraid the Q Bluetooth remotes do not use codes but work on Brand and Model.
Have you tried Other brands in the pairing setup?
Message posted on 30 Nov 2023 07:03 PM
Sorted in one.
thankyou so much.
Message posted on 05 Dec 2023 07:07 PM
Can you tell me how you sorted this out please.
Message posted on 05 Dec 2023 08:28 PM
When it asked for the tv brand I scrolled to the bottom and selected other brand. Worked first time.
Message posted on 05 Dec 2023 08:35 PM
Thanks @Heath1
Message posted on 20 Dec 2023 05:22 PM
I have the same tv, same problem but tried using "other brand" and it still says the tv is not supported.
Did you have to reset the q box and remote somehow? We had the remote set up on our old Sony tv previously.
Message posted on 20 Dec 2023 05:39 PM
Using the q remote
press home
scroll down to settings
scroll right one
scroll down to setup
scroll right one
scroll down to remote control
scroll right and select sky Q remote
select control your TV
enter o
enter t
select 1st other brand
scroll down and select find it for me
first setting offered here worked for my tele.
I hope that helps. I just went through it as I wrote so should be the same.
Message posted on 20 Dec 2023 05:44 PM
Thank you - perfect!
Message posted on 06 Nov 2024 12:27 PM
That's great! I still have to use my JVC remote to turn on the tv is this right or do you know a better way?
