Discussion topic: Projector for sky mini q
Message posted on 29 Mar 2024 07:16 PM
Please can someone suggest a cheap Projector that I can connect to sky mini q
that definitely works!! And I'm assuming an hdmi cable out from the mini and into the projector will just work for Netflix, football etc (via Sky)
there is so much conflicting advice around that I can't find a sensible answer.
thabks so much in advance
Message posted on 30 Mar 2024 08:39 AM
							Re: Projector for sky mini q
There's nothing special about the HDMI output of a Q Mini box: it's HD resolution with HDCP appropriate for commercial HD resolution.
Message posted on 30 Mar 2024 08:41 AM
Ok cheers. Can you recommend a cable and projector that will work then?
Message posted on 30 Mar 2024 10:09 AM
@Zaggle wrote:Ok cheers. Can you recommend a cable and projector that will work then?
@Zaggle the HDMI cable supplied with your Sky Q Mini
This was purchased for my son for his Sky Q Mini in his bedroom but it was quickly used for his PS4 when friends came over.
It was under £65.00 and well worth the money.
There are a lot of better ones but it depends on what features you are wanting
Message posted on 30 Nov 2024 04:06 PM
Hi,
im also looking g at buy a projector for another room. I have SkyQ and mini box but none of them actually say they work with it! Don't really want to spend more the £200 tho
