Discussion topic: Sky Q WiFi Settings
This message was authored by: turnbacktime
Sky Q WiFi Settings
Has anyone experienced their wifi setting change unexpectedly. Earlier this year I turned WiFi off on both my Sky Q boxes, main and mini.
, after connecting them via Ethernet. I confirmed they were off with a WiFi analyser on a mobile phone. A couple of months later the mini was getting glitchy again. Look in settings and wifi back on in both boxes. Turned it off and double checked a couple of weeks later.
Changed broadband yesterday, which shouldn't have made a difference as on Ethernet, and neither box was connected to internet. Go into settings and both boxes had, at some point, reverted to WiFi.
Re: Sky Q WiFi Settings
@turnbacktime
Yes, this seems to be by design.
It was always intended to be a wireless mesh network set up with the main Q box acting as a server to the Q mini boxes, but over the years many people have ended up with a mix of wireless and wired for stability.
The boxes do tend to do a reset when there is a change, looking to go back to that default behaviour. At least you know what to check first now when it does happen. 👍
sky Q 2 TB | sky Q Mini | sky Mobile | EE Full Works FTTC | LG B6 OLED | SONOS Beam 2
Avatar for turnbacktime
Level 4 icon
Thanks. I hestitate to accept it is works as designed. Or if it is I think it is a poor design. Still, as you say I know what to look for now. The question being how often to check.
My rule of thumb is, if it is working, don't touch it!
