Discussion topic: Pixle screen when watching tv
This message was authored by Jbourke This message was authored by: Jbourke
Screen is pixleating when trying to watch a movie through prime via sky q
This message was authored by stereohaven This message was authored by: stereohaven
Re: Pixle screen when watching tv
This is an intermittent but common problem across a number of apps on Q at the moment.
Sky is aware and we await a fix. See this thread.
LG B6 OLED 55” | LG UP75 LCD 43” | Sky Q | Sky Q Mini | Apple TV 4K | SONOS Beam 2 | Sky Mobile | FTTC BT Halo 3+
This message was authored by Invisiblename This message was authored by: Invisiblename
@Jbourke  in the meantime, if you've got a smart TV, you can use the Amazon Prime app on that (not through Sky)
I am just another Sky customer!
This message was authored by JibbaJoy This message was authored by: JibbaJoy
The ANSWER to this the pixelating thread is basically just wait for sky to fix it with a software update 😖
There was a software update of 14th August, version Q270.000.10.02L (5u193hm), but this didn't resolve the issue.
It can affect live tv (through sky) and mini box viewing as well as streaming apps.
SkyQ [H/W: 32B106] + 3 mini
Samsung 55" Neo QLED UHD TV
Swish Fibre 150 Symetrical
Linksys MX5400 Mesh network
Correct.
Because not everyone is seeing the issue, it comes and goes for others and the apps it effects is also not consistent, which I suspect makes any root cause difficult to pin down.
Maybe because there was nothing in it to try and fix it, but was an update for something else?
When Sky deliver an update and it has a specific fix for a problem, they tend to tell people that is what is happening.
Can it?
I haven't experienced any issues. How do you know that the same problem affects live TV as well as apps?
@stereohaven wrote:
@JibbaJoy wrote:
The ANSWER to this the pixelating thread is basically just wait for sky to fix it with a software update 😖baJoy wrote:
Can it?
Yes it can but not as bad as streaming apps. I've seen it and it's being seen by the other 3 adults and 2 kids in my household.  We have 3 mini boxes and they can freeze or show a black picture as well as pixelisation.
Jbourke
Thank you all very much for your help 🤗
