Discussion topic: mini q box not working
This message was authored by: field996
my mini q box is broken.
Avatar for field996
Level 0 icon
Re: mini q box not working
it's broken issue cannot be fixed
@field996
You'll have to expand on that.
Hi @field996
Unless you have broken it half @field996
Reboot the mini as above.
Avatar for field996
Level 0 icon
it's frizen
@field996 wrote:
it's frizen
See my earlier post @field996
Avatar for field996
Level 0 icon
Re: Where can I buy a new Sky Q Box?
i can't get to speak to them to do this. does anyone have an email
@field996  Sky doesn't use email has communication route so you will have to call
@field996
No need to post on another thread as you have this one. You can't buy a mini box. Sky don't use email as a general method of communication.
If your mini box is definitely broken call Sky and arrange either an engineer or a replacement box.
