45
This discussion topic has been answered Discussion topic: Paramount + causes Sky Q box fan to go loud and stay on
This message was authored by: Greased+Lizard
When watching anything on Paramount + app on Sky Q 2tb box, there is frequent buffering, and then after about 20 minutes, the fan comes on and stays on until the box is physically switched off.
This ONLY happens with Paramount +. Every other streaming app works absolutely fine, without any issues.
I've seen a few other threads like this, but none of them had any solutions.
I've tried the usual, rebooted the router, the Sky Q box, and refreshed the apps, and none of those have worked.
WiFi connection to the sky Q box is good, ran a speed test through Netflix on the Sky Q box and was getting over 62mbps. Netflix, Amazon Prime, Disney+ and Apple TV all work flawlessly, and in 4k (where available).
It seems there's something wrong with the Paramount + app and the way it interacts with certain hardware maybe?
Anything else I can try, or any news on an update to the app/Sky Q firmware?
Sky Q box: Hardware version 32B106, software version Q220,000,23,00L
This message was authored by: Daniel-F Answer
Re: Paramount + causes Sky Q box fan to go loud and stay on
Posted by a Sky employee
Hi all 🙂
We have picked this up and looking to investigate things further.  We will keep you updated once we know more information.
Thanks,
Daniel
Community Moderator
Hi @Greased+Lizard
This message was authored by: Clark1978
When watching paramount + the sky Q box makes a terrible noise like the fan is working overtime.
When I watch paramount + on sky Q it buffers and the box itself makes a terrible noise like the fan in the box is going nuts. The only way to stop it is to turn the box off at the mains.
This message was authored by: Greenfingers001
Re: When watching paramount + the sky Q box makes a terrible noise like the fan is working overtime.
My sky q box buffers then mashed a loud fan like noise when watching paramount + on the app, the only way to stop it is to turn the box off at the mains power.
This message was authored by: Addie15
Update-We are closing this session now due no further response within 48 hours. If you still need help, please let us know so we can re-escalate this for you. Thanks.
This message was authored by: LindaCY
When watching paramount plus, buffering and loud fan noise,on q box
I have just signed up to paramount plus. When watching there is loud fan noise and buffering. I see this appears to be a known problem. What is solution?
The fan on box kicks in when watching paramount plus. I've reset box and refreshed apps to no avail
Fan makes noise, when watching paramount plus. I've reset box and refreshed apps. As sky have known about this issue for a while, why has it not been sorted?
This message was authored by: Lisa-P1987
Re: The fan on box kicks in when watching paramount plus. I've reset box and refreshed apps to no...
Hi there @LindaCY , I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Lisa - Sky Tech Team Expert
This message was authored by: Jemma18287
Hi I'm having the same issue. When watching paramount + it buffers then the box sounds like it's going to explode. I've reset and unplugged all cables. The box is on its own not near any heat source or tv and well rentilated
@Jemma18287
As your issue is the same as that of the OP I’ve escalated your post to Sky and the Messaging Team may get in touch with you later.
Look out for a blue/red speech bubble at the bottom of your forum page. Once that appears you have 48 hours to click on it and join the private chat or it will close automatically. If you fail to respond to each chat reply within 48 hours the chat will again close down automatically even if your issue hasn’t been resolved. Replies from Sky are not instant so you’ll need to regularly check the chat thread.
This link explains the Community Messaging process.
Fantastic thanks for your help
Thanks for escalating this. We’ve sent @Jemma18287  an invite to chat.
Hi I did private chat and was told to reset the apps. It did work initially however the same has started to happen again. Can someone please help me again. Thanks
This message was authored by: L3EDX
I have the same problem.  Only happens with Paramount Plus and on the main Sky Q box.  Buffering circle also appears a lot.
doesn't go away even after leaving app always have to power off and on the box for fan to return to normal.
Answered - Go to Answer
