This discussion topic has been answered Discussion topic: PIN number
Message posted on 19 Oct 2024 05:15 PM
Forgot my PIN number
Message posted on 19 Oct 2024 05:18 PM
@nicolanorth Try last four digits of your viewing card number
Message posted on 19 Oct 2024 05:27 PM
Re: PIN number
Unless you have changed it, then as @SKY1992bf states your pin number is usually the last 4 digits of your viewing card number. You can find your viewing card number in Home > Settings > System info.
Message posted on 19 Oct 2024 10:44 PM
Re: PIN number
With sky q, you can reset your tv pin via the my sky smart phone app.
On the icons at the bottom, go 'tv'
Then 'product settings'
Then 'manage pin'
ROI sky Q Customer.
Message posted on 20 Oct 2024 12:03 AM
Re: PIN number
@nolte wrote:With sky q, you can reset your tv pin via the my sky smart phone app.
Then 'manage pin'
There's no "product settings" on the TV page for me?
Message posted on 20 Oct 2024 12:18 AM
Re: PIN number
Then 'manage pin'
It is on mine
ROI sky Q Customer.
Message posted on 06 Feb 2025 07:34 AM
Re: PIN number
I FORGOT MY PIN
Message posted on 06 Feb 2025 08:12 AM
Re: PIN number
You don't appear to have read the above replies to the same question, so unless you have changed it, then as @SKY1992bf states your pin number is usually the last 4 digits of your viewing card number.
You can also find your viewing card number in Home > Settings > System info.
