4
This discussion topic has been answered Discussion topic: Sky Q recordings
This message was authored by: Teddy1975
Sky Q recordings
Hi
juss before I commit to sky q multi rooms - can I check understand it right?
have some recordings on Sky Q box but I want to be able to watch them on the sky go app - quick search seemed to indicate I need Multiscreen enabled to get this feature - am I right?
This message was authored by: Quoman7 Answer
Re: Sky Q recordings
@Teddy1975 wrote:
Hi
Hi @Teddy1975 When you subscribe to Multiscreen you can Get Sky Go Extra at no added cost, and watch live TV or download on demand shows on up to four devices (in line with your TV subscription).
@Teddy1975 wrote:
Hi
@Teddy1975 wrote:
Hi
hi @Teddy1975
Yes multiscreen allows you to watch recordings from your SKY Q box & download them to your device if wanted.
Note:  To view on and/or download to,  your device must be on the same network as the SKY Q box
Once downloaded you can watch away from home but there are time limits on starting and then complete watching (unfortunately I can't remember these off the top of my head)
@Teddy1975 in addition to @nigea99 post you will not be able to download anything recorded on you Q box from the BBC channels and a couple of others as they want you to use their own streaming app ie IPlayer
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for Teddy1975
Thanks for your help everyone - much appreciated.
