7
This discussion topic has been answered Discussion topic: PIN number
This message was authored by: nicolanorth
PIN number
Forgot my PIN number
This message was authored by: SKY1992bf Answer
Re: PIN number
@nicolanorth  Try last four digits of your viewing card number
Please note: I am just a sky customer not a employee - posts from sky employees are clearly marked as such
Re: PIN number
Re: PIN number
@nicolanorth
Unless you have changed it, then as @SKY1992bf states your pin number is usually the last 4 digits of your viewing card number. You can find your viewing card number in Home > Settings > System info.
▪️I AM NOT A SKY EMPLOYEE (undercover or otherwise) ▪️
This message was authored by: nolte
Re: PIN number
With sky q, you can reset your tv pin via the my sky smart phone app.
On the icons at the bottom, go 'tv'
Then 'product settings'
Then 'manage pin'
ROI sky Q Customer.
Re: PIN number
Then 'manage pin'
There's no "product settings" on the TV page for me?
Re: PIN number
Then 'manage pin'
It is on mine
ROI sky Q Customer.
This message was authored by: DOG54
Re: PIN number
I FORGOT MY PIN
Re: PIN number
@DOG54
You don't appear to have read the above replies to the same question, so unless you have changed it, then as @SKY1992bf states your pin number is usually the last 4 digits of your viewing card number.
You can also find your viewing card number in Home > Settings > System info.
Answered - Go to Answer
