Discussion topic: Not connecting to internet
This message was authored by: JayC93
My SkyQ box will not connect to the internet. I have tried all methods available on the box but cannot get it to work.
other devices in the house are able to connect to the broadband fine but I can't connect the box to broadband via WPS button, entering my password or a wired connection.
i don't have the option to reset or anything as has been suggested in other posts previously
Re: Not connecting to internet
Hi @JayC93
Assume this is your main Q box.
An Ethernet connect (if carried out via a Network Reset without WPS) should be faultless.
You haven't specified your broadband supplier.
To connect by WiFi
Try a Network Reset found in Q box Home - Settings - Setup - Network.
Avatar for JayC93
Thanks for the response
I am a sky bb customer too. I don't have the option to reset the network through settings on the main q box.
ive tried connecting to phone hotspots too and still can't connect at all.
Is there a way to force a network reset? We have already tried unplugging both router and q box for a long time before retrying.
thanks
Hi @JayC93
Exactly what do you see when you go to Settings Network
Avatar for JayC93
 this is the screen I get. I've tried all 3 options here without success
Hi @JayC93
If you have Sky Broadband and a Sky Q router there is only the one option.
What happens when you select this option?
Avatar for JayC93
@oldfella58 it tries to connect for around 2 mins then pops up with unsuccessful
Hi @JayC93
What instruction do you get when you select connect to Sky Broadband?
Avatar for JayC93
@oldfella it says to complete the connection to press and hold WPS button. Even when I do this I still get unsuccessful
Which WPS button are you pressing?
Avatar for JayC93
@oldfella Its on the side of the bb router - it matches the symbol on the instruction.
Was the WPS light flashing on the main Q box before you went and pressed the WPS button on the router?
Also did your press the Button on the router within 2 minutes?
You say you pressed and held the WPS button on the router.  You didn't hold it while the light was flashing on the router did you?
Avatar for JayC93
@oldfella thanks for your patience. I wait until the q box flashes before pushing the button on the router. I hold it for a few seconds and release. I can see the orange light on both boxes flashing but they won't seem to connect with each other
Ok @JayC93
The procedure you are following is correct.
Try rebooting your Q router by disconnecting the power lead for 30 secs and then reconnecting..
Wait until the router is completely back up and running and then reboot the Q box.
Then try the WiFi procedure again.
Avatar for JayC93
@oldfella no luck after following these steps
