Discussion topic: Not connecting to internet
This message was authored by: BOX12
Re: Not connecting to internet
I've had an email saying there's a reply on this thread. No request to chat
no blue/red bubble?
This message was authored by: Lisa-P1987
We are still looking to help you BOX12 . If you need our support let us know and we can re-escalate to our chat team. Your invite has been closed now. Thanks
Lisa - Sky Tech Team Expert
This message was authored by: Toad+face
I have exactly same problem, what is the fix ?
That's a big assumption
What have you already tried?
This message was authored by: PaulMoon
I'm having this issue. Switched to sky fibre a month ago from their super fast and was fine until today. Internet not connecting to sky q boxes. Tried following directions including holding WOS on sky max router when prompted but it does nothing. Any help much appreciated.
I believe you don't use the Sky router / WPS process with the Max router. You connect using the password as if it's a non-sky router.
This message was authored by: thecardman
I am having a similar issue. Woke up this morning to find the mini box wasn't connected and with a message telling me to go to the Sky Q box and follow instructions.
  • Pressed the WPS button on the router but it did not reconnect
  • Reset the router then tried the WPS bit again. Nothing.
  • Switched off mini boxes, Sky Q box and router. Restarted router. Once it was fully up and running - internet working fine - restarted the Sky Q box. Still not connecting to the Internet.
The Sky Q box and router are about a foot (30cm) apart. Any help/advice would be appreciated.
30cm? Use a cable.
This message was authored by: Palo4321
The lights are not working only 2 lights are green
@Palo4321
The below link explains the lights on the various hubs https://www.sky.com/help/articles/hub-lights-explained-start
This message was authored by: RoosterRoo
I've just finally resolved my Sky Q box not connecting to WiFi or via Ethernet.
My setup is as follows:
BT Internet ISP
Draytek 2830 router (this is the DHCP server as well)
TP-Link Deco X55 AX3000 Mesh WiFi network in access point mode.
My Sky Q box would not connect to WiFi or via Ethernet.  It would obtain an IP address and momentarily say it was connected to the internet but then would show an x.  I tried a factory reset on the Sky Q box and still nothing.
Finally, after checking a load of settings on my DrayTek router I noticed  RADVD was enabled but DHCPV6 was disabled.  This was triping the Sky Q box up.
After fully disabling IPV6 everything is working correctly.
Hope this helps someone!
Interesting. I use IPv6 on my network without breaking the Q but it's entirely possible that ipv6 radvd traffic doesn't make it through my ancient wifi mesh to cause any confusion.
This message was authored by: RomonAth34
Just got Fiborus but now no internet broadband
Just got Fiborus put in. But now I have no broadband or lnterneth have tried everything please help
