4
This discussion topic has been answered Discussion topic: No netflix. Broadbsnd connectivity
This message was authored by: Roy+wx
Power outage 3 days ago. Lost home phone line and broadband. Home phone back on day 2. Broadband back day 3. But no connectivity between hub and router
Rebooted etc but no change. No apps working. Broadband working from mobile
Re: No netflix. Broadbsnd connectivity
Hi @Roy+wx
Have you carried out a Network reset on your main Q box?
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
Hi @Roy+wx
Avatar for Roy+wx
Level 2 icon
Network reset fails
Avatar for Roy+wx
Level 2 icon
In my ignorance I got the 2 boxes mixed up.. what was suggested worked. Perhaps the boxes should be different colours or markings on them to distinguish them from each other for laymen like myself? Thanks to all helpers
Which 2 boxes?
Edit: Oh the Sky Q box and the "Sky Q hub"? Have you got one of those routers? Stupidly named and yeah they do like quite similar to the Q box - 3 status lights instead of just the power one and I guess most people don't have them both near the TV though.
Answered - Go to Answer
