85
Discussion topic: Netflix often not working on SkyQ
This message was authored by Collinsc This message was authored by: Collinsc
Hi
Netflix is often not working on SkyQ. We have checked the Netlfix website and there are no problems with Netflix itself.
We rang up before and sky had directed us to the hidden menu to "refresh apps". However, the "Refresh apps" is no longer there, or perhaps moved?
We have Sky Broadband Ultrafast 1 (FTTP) and are getting good speeds.
Advice appreciated on what might be causing this issue, and where we can locate "Refresh apps".
This message was authored by Chloe-W22 This message was authored by: Chloe-W22 Answer
Re: Netflix often not working on SkyQ
Posted by a Sky employee
Hi all,
I wanted to let you know Sky are in constant contact with Netflix and are working to get to the bottom of feedback shared on this thread.
The Community team will update the thread as we know more and, in the meantime, if anything changes please let us know.
Thank you for your comments and understanding,
Chloe-W22
Community Manager
Have a story you want to share with us? Send your Thanks to Sky here
Collinsc
How can i get this question in front of a sky employee?
This message was authored by SlenderRobert This message was authored by: SlenderRobert
@Collinsc
Try the following:
To enter hidden menu press Home and navigate down to Settings but do not select Settings. With Settings highlighted press 0 0 1 Select. then highlight Refresh all Apps on this box.
Sky Q boxes are quite long in the tooth now and were never initially designed to host apps so they do tend to be slow and prone to locking up.
For a better Netflix experience I'd recommend using the Netflix app built into your smart TV (if you have one) or a dedicated streaming device such as a Firestick, Roku or Apple TV 4K box.
Collinsc
Thanks robert
as mentioned in my post however, the "refresh apps" is no longer on that hidden menu.
I really need to speak to someone from sky about this. I would have expected a response by now as it has been 5 days since I posted
This message was authored by Chodley This message was authored by: Chodley
Sky employees have responded (or been quoted) in the other threads on this subject iirc
This message was authored by lettice This message was authored by: lettice
@Collinsc wrote:
Thanks robert
Refresh apps has not been removed. From the hidden menu in Sky Q.
To refresh your apps;
On Sky Q:
  1. Press Home on your Sky Q remote, then highlight Settings
  2. Press 0,0,1 and Select to access the Installer menu
  3. Select Apps then highlight Refresh all Apps on this box. You'll see a message that says, 'Your apps are being refreshed'.
  4. Press Dismiss to return to normal viewing.
The refresh can take 24 hours to complete.
Also, have a browse of the guidance here;
https://www.sky.com/help/articles/apps-on-sky-q-and-glass
Sky Community Superuser
Sky Q V2 main & mini, Sky Ultrafast + using Sky SR203 hub. Sky Protect kit tester.
Collinsc
Thank you!
yes I was missing a step!
still need someone from sky now though to talk to about the Netflix issues
@Collinsc wrote:
Thank you!
After reading link above, not just doing a refresh of the apps.
What problems are you getting with Netflix on Sky Q.
Any error messages?
Collinsc
I'm afraid there are no error messages. The Netflix screen appears and that is all
This message was authored by Laing1 This message was authored by: Laing1
@Collinsc have you seen the answer from a Sky employee in the thread below not sure if it will help you but worth looking at
https://helpforum.sky.com/t5/Sky-Q/Netflix-app-crashing-won-t-load/m-p/4435511#M603465
Collinsc
Thanks. We arent facing the issue at moment so cant test that out.
What I want is for a sky employee to explain why this might keep happening and what recompense we can have.
@Collinsc afraid no one on the forums would be able help with this you would need to contact Sky by either calling or making a complaint
You can contact Sky by phone by dialling 150 if Sky is your phone provider or by following the link below
https://www.sky.com/help/home
scroll down to need more help click on this and you will find a phone number. If you are in ROI please change the flag at the bottom right to the ROI flag
Is it a black screen or a spinning icon.
If it's one of either, often a cure is to login to your Netflix account via a web browser and force sign out of a device, in your case your Sky Q box.. Just do a force sign out of your Sky Q box, not all devices.
As described here.
https://help.netflix.com/en/node/128180?q=How%20to%20sign%20out%20of%20a%20device
But, would still recommend doing the app refresh..
That sometimes does take many hours, so do it and try the app in say the next day.
Collinsc
Thanks all for the advive - will give them a go next time and contact sky if not fixed
This message was authored by Mattzoe This message was authored by: Mattzoe
Netflix isn't connecting to our sky Q box. We've tried refreshing the apps still nothing. Was working fine until recently.
