2507
This discussion topic is read only This discussion topic has been answered Discussion topic: Netflix has encountered an error. Code: tvq-st-102
Locked
This message was authored by: Karen109
Re: My Netflix isn’t working
I often can't load Netflix either, just buffers and sometimes throws me back to sky. It does work every third or fourth try when I try again later. Internet connection fine with no problems loading other apps.
This forum is for Sky GO inquiries
Please post in the relevant forum for your system, see list below, thanks
1. Sky Plus (Sky Plus Forum)
2. Sky Q (Sky Q Forum)
3. Sky Glass & Live (Sky Glass & Live)
4. Sky Stream (Sky Stream)
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
This message was authored by: NoOne
Re: Netflix: Red Spinning Circle on Launch
I have same issue it's constantly playing up has been for ages I don't think sky knows how to fix it
has anyone managed to fix it
thanks
This message was authored by: Meems
Sky hasn't me this on Monday -
Hi, it's Kristina from Sky!
We are currently rolling out a new version of the Netflix app, which should improve this issue for affected customers. I will keep you informed about the issue. Have a good day ! NoReply
Very annoying!
This message was authored by: swhxd06
That's exactly what I was told several weeks ago. Very soon after that, mine started working again - and it has continued to do so. Hopefully, everyone else's will be fixed soon too 🤞
It isn't working yet!
This message was authored by: BaileyGB
Please try this fix guys. It worked for me and plenty of others on this stream.
1 - Log into Netflix via the web browser.
2 - Highlight your profile picture (Top right corner).
3 -  Click on Account.
4 - Under the Security and Privacy option, click on Manage access and devices.
5 - Select the device name: (it may be called SkyQ ......or Sky UK Set-top box).
6 - Select--> click on the "Sign out" option on the SkyQ ......or Sky UK Set-top box.
7 - Go to your SkyQ box and launch the Netflix app on your SkyQ box.
Will that interfere with other devices. We have s smart tv upstairs and the usual iPads , phones etc
You'll just need to log back in on each device.
It hasn't worked. Still the circle of doom unfortunately!
We have Netflix.., let's see if it lasts!
This message was authored by: Andrew_cusick
This is weird, but clearly a Sky box issue - I have sky q with repeater box upstairs. The main box gets red circle of death, but the repeater box loads netflix ! - go figure that ! , I've tired all the various resets etc. and sometimes you get a day or two respite, other times it doesn't work at all £102 a month and I can't get the full service - pretty rubbish guys
This message was authored by: Padam_Padam
When you say 'repeater box' do you mean a Sky Q minibox?
This message was authored by: Paul+Com
Got Sky Q box plus two mini boxes. Sky Q box and one mini box get Netflix ok. I've given up with the other mini box, if I want to watch Netflix on that TV I don't bother with the mini box, I just use the app on the TV to watch it.
No because you are just forcing logouts on your Sky devices.
Locked
Answered - Go to Answer
