2507
This discussion topic is read only This discussion topic has been answered Discussion topic: Netflix has encountered an error. Code: tvq-st-102
Locked
Re: Netflix won't load on SkyQ.
@ClaireK3 wrote:
Netflix won't load on SkyQ, the red circle just constantly turns. I have refreshed the app, turned the Sky box off and on again and signed out on Web browser. Nothing has made any difference. Any other suggestions please?
Did you sign out of all devices on the web browser or just sign out of Netflix? If devices, did you reboot the Q box afterwards?
This message was authored by: Blackbird5
Re: Netflix spinning
Unable to load Netflix spining red circle
@Blackbird5
See post 2 currently marked as the answer.
▪️I AM NOT A SKY EMPLOYEE (even undercover)▪️
This message was authored by: Macca77
Re: Netflix: Red Spinning Circle on Launch
why are we paying for this. absolutely disgusting service
@Macca77
What you need to do has been posted multipke times including the post marked as the answer so have you done this yet ?
This message was authored by: Lisa16111
Netflix isn't working on my sky Q  box, down stairs or upstairs I've tried everything, I think it's to do with sky Q as it works on my daughters telly
When you say you've tried everything, have you tried the following which seems to be the only permanent fix?
  1. Log into Netflix via the web browser.
  2. Highlight your profile picture (Top right corner).
  3. Click on Account.
  4. Under the Security and Privacy option, click on 'Manage access and devices'.
  5. Select the device name: (it may be called Sky Q ......or Sky UK Set-top box).
  6. Select--> click on the "Sign out" option on the Sky Q ......or Sky UK Set-top box (do this for all Sky devices listed).
  7. Reboot Sky Q box by turning off at the wall or plugging out for 1 minute (do the same for mini boxes but boot up the main box fully first before rebooting the mini boxes).
  8. Go to your Sky Q box and launch the Netflix app on your Sky Q box.
If it's easier for you, points 1 to 6 amount to the following:-
Go to your account online through a browser and sign in if necessary, from your portrait/avatar, go to 'Account', then 'Devices', then 'Access and Devices' and then sign out of all Sky devices listed.
The direct web address is:- netflix.com/manageaccountaccess which can be copy & pasted into your browser.
Don't forget to reboot the Q boxes after the above.
You can use the app on a smartphone to sign out of devices also.
This message was authored by: Clive07
Red spinning wheel on Netflix on my Sky Q box signed into Netflix on web browser find devices and sign out of Sky box.  Whilst doing this turned power off Sky Q after restarting up box opened Netflix app and signed in again problem solved. This is not the first time this has happened so maybe there's a bug that needs fixing by Sky as my multi room boxes never a problem only on Q box
Do make sure that you've signed out of devices and give it a minute before rebooting the Q box. You have to allow them to sync.
This message was authored by: Stormy78
Are Sky going to ever fix this problem? I have reset the app, cleared saved devices on netflixs, rebooted the main sky q box and router and I still have the red spinning circle. Netflix works on the smaller sky q boxes but not kn the main box. Please get this fixed!!!
This message was authored by: PETROS+PETRA
@Lisa16111
Folllow instructions from @Anonymous
This message was authored by: VM1
Re: Netflix app not opening
Netflix is not opening in mini box
@VM1
Same question then… Are you just seeing a red spinning circle?
Yes. Just spinning circle
@VM1
I've merged your post into the large thread discussing this issue that some customers are experiencing. See the post currently marked as the answer (post 2).
Locked
Answered - Go to Answer
