Discussion topic: Netflix has encountered an error. Code: tvq-st-102
Message posted on 09 Jun 2024 01:30 PM - last edited: 09 Jun 2024 01:31 PM
							Re: Netflix capacity issue?
@Alan329 wrote:
This suggests that at peak times there is a capacity issue which is not great when you can't use a service you are paying for.
Possibly, but that's likely to be with the Netflix content distribution network rather than Sky.
Message posted on 09 Jun 2024 02:51 PM
My nefllex isn't work on my sky q box but working everywhere els
Message posted on 09 Jun 2024 04:08 PM
@steed whats happening or what are you seeing when you try to open it
Message posted on 09 Jun 2024 04:35 PM
I'm having the same red spinning disk issue over the last few days but in my case thiseezes the q box and the only way out is to put the q box into standby and then switch on again.
Using the Netflix app on the smart tv instead.
Message posted on 09 Jun 2024 04:55 PM
							Re: Netflix capacity issue?its ok all fix i just had to.pull plug out for a minute or 2 re plug back
All fine now just had to pullmplug out for a minute or 2 the plug back in all working now
Message posted on 10 Jun 2024 10:05 AM
							Re: Netflix: Red Spinning Circle on Launch
I've had to do this several times. It works well, then just won't load. After removing device from Netflix it works again... eventually.
Message posted on 10 Jun 2024 09:16 PM
Mine isn't working red circle tried everything 😭
Message posted on 10 Jun 2024 11:22 PM
I e had this issue for the first time tonight, tried the answer thread solutions and it's not worked (the last one i could not get to work). Just tried unplugging the box and that has worked
Message posted on 10 Jun 2024 11:39 PM
It will work for one day then tomorrow you might have the same problem. I did the reboot of both boxes the internet and the sky box that worked but think this issue will be ongoing.
Message posted on 11 Jun 2024 01:29 AM
As above, doing the steps given may let it work for a day or if lucky several days but then the issue will come back. For us we had this constantly happening but for teh past month or 2 it suddenly vanished and was fixed, by means not by us. Which means this is deffinatly a sky/netflix issue and they should eventually get round sorting you out.
My worry is if they change something and everyone goes to kaka again. No ammount of us trying to sort things will work, they will be temporary and you MUST wait for sky to fix it.
Message posted on 11 Jun 2024 08:06 AM
@Em80 wrote:I e had this issue for the first time tonight, tried the answer thread solutions and it's not worked (the last one i could not get to work). Just tried unplugging the box and that has worked
By the last one, do you mean the following:-
Opt out of A/B test groups:
- Log into Netflix via the web browser
- Highlight your profile picture (Top right corner).
- Click on Account.
- Scroll to the bottom
- Turn OFF test participation
- Reboot device.
If so what happens?
Message posted on 11 Jun 2024 03:07 PM
TBH I couldn't find "test participation on my Account" ! - I do find that logging out of all attached machines and then a re-log in seems to clear whatever corruption seems to get in the way
Message posted on 11 Jun 2024 03:12 PM
"Test Participation" should be right at the bottom of the account page
Message posted on 11 Jun 2024 03:15 PM
@Andrew_cusick wrote:TBH I couldn't find "test participation on my Account" ! - I do find that logging out of all attached machines and then a re-log in seems to clear whatever corruption seems to get in the way
Have you tried this?
1 - Log into Netflix via the web browser.
2 - Highlight your profile picture (Top right corner).
3 - Click on Account.
4 - Under the Security and Privacy option, click on Manage access and devices.
5 - Select the device name: (it may be called SkyQ ......or Sky UK Set-top box).
6 - Select--> click on the "Sign out" option on the SkyQ ......or Sky UK Set-top box.
7 - Go to your SkyQ box and launch the Netflix app on your SkyQ box.
Message posted on 11 Jun 2024 03:22 PM
