38
This discussion topic has been answered Discussion topic: Netflix freezing
This message was authored by: SimonK1982
Netflix freezing
Hi guys, over the past few weeks I've had a constant issue with Netflix on my SkyQ box and mini box.
First it will load and let me scroll but when I try to select something it freezes on the tile.
I press the home button and retry loading Netflix but I just get a black screen.
I've done a reset on both boxes and since then I've unplugged both boxes for a few minutes and have had no joy.
I don't have any continuous problems with other apps.
Any advice on steps would be appreciated.
This message was authored by: KevNewMedia Answer
Re: Netflix freezing
Posted by a Sky employee
Morning Everyone
Thank you very much for making us aware of this problem, and we apologise for the problem.
Our Support teams are currently investigating this problem, and we will update you as soon as we have more information.
In the meantime, I'll mark this post as answer, so people have the most up-to-date information. It doesn't mean it's fixed, it's so people know we are investigating.
Kev
Community Manager
This message was authored by: Bifta
Netflix
Hello all.
I have come across an odd issue on Netflix.
If I load the app on my mini box and then play something it works fine.
If I go to new and popular in order to check what is coming over the next few weeks and look at what is new on Netflix the app freezes completely. The only way to manage to do anything is to exit the app. If I then load back into the app after exiting it I get a black screen. If I then load up another app like Paramout + and then load up Netflix afterwards it allows me back into the app and again I am able to watch tv via the app perfectly normally. Again if I then go back to the new and popular section it freezes the app for me.
I have had this happen 5-6 times in a row now so it seems to be happening evertime.
It therefore looks like something is happening with the new and popular section of the app that is causing it to freeze up.
Re: Netflix
First, try a power reset of your Sky Q box, leaving off power for 30 seconds.
If the Netflix issue still has the fault you mention, try refreshing your apps on the Sky Q box.
  1. Press Home on your Sky Q remote, then highlight Settings.
  2. Press 0,0,1 and Select to access the Installer menu.
  3. Select Apps then highlight Refresh all Apps on this box. You'll see a message that says, 'Your apps are being refreshed'. This will stay on screen until you press Dismiss to return to normal viewing - we recommend waiting at least 5 minutes before doing so.
The refresh can take 24 hours to complete once you have returned to normal viewing
Hi @SimonK1982
Best and correct way to exit Netflix is to to use the Exit Netflix option at the bottom of the left hand Netflix menu.
In the same left hand Netflix menu select Get help and on the next screen there is an option to Reload Netflix.
Try this and see if it helps your Netflix freezing issue.
Avatar for SimonK1982
Level 2 icon
  • Thanks for the response,
I'm not able to get out of Netflix any other way than the Sky or Home button.
The cursor won't move from whatever's highlighted.
I've had another look and I can select and play items that are available but anything on the coming soon menu instantly freezes.
I've tried about 5 times to set a reminder for different items.
I'll check out that help menu before I select anything next time it loads
This message was authored by: phillip+watson
Netflix not opening properly
Currently I can seldom get onto Netflix on my Sky q box.
Sky have tried to assist without any success.
Any suggestions as to a solution.
When I do get on I have a navigation issue when I go to move about on the new and upcoming 'tiles'. I can't move  away from them or scroll across using the remote!! Also I have noticed the drop down list on Netflix on the main box shows 'Latest' for all new and upcoming stuff but on my minibus the equivalent heading reads ' New and popular', which was how it was on the main box until a few months ago.
This message was authored by: PT85
I've been getting the same problem for the last few days. I can navigate most menus fine, but when I go to the Latest screen it freezes when I try to move around the list of shows.
This message was authored by: andrew238
Re: Netflix
I've got the same thing happen. If anyone can help
Re: Netflix
Have you tried refreshing the apps as I mentioned above?
This message was authored by: Addie15
Re: Netflix not opening properly
This message was authored by: G.k.s
Re: Netflix
Doesn't work
This message was authored by: Viking
Have same issue contacted Netflix and they said the app needs updating as the menu has changed and speak to sky to update app.
@Sky do you have an update yet on how to resolve the issue of Netflix freezing when you're in the New & Popular section? Unplugging it, refreshing apps etc is not working.
Sky sending me new box maybe app updated on that.
This message was authored by: Liz126
We're having the same problem, is there a resolution yet please?
Answered - Go to Answer
