6
This discussion topic has been answered Discussion topic: TV not linking with SKY Q box
This message was authored by: Willo2
My TV is working, I can use smart apps on it. When I turn my sky Q box on, the screen just stays black. I've unplugged everything and started again but no luck. SKY said it could need a new HDMI, I've just changed to a new one and still nothing. The Sky Q box has a green light, remote turns it on and off, but nothing happens on the TV.......Any help?!
Re: TV not linking with SKY Q box
@Willo2 wrote:
Yep tried that. I've just brought my gaming monitor into the room, and connected the HDMI with that and it works fine. So the skybox isn't the problem. Must be something wrong with the TV, but the smart apps work fine.
Hi @Willo2
Have you tried a different HDMI input on the television?
You could also try rebooting the Television
Hi @Willo2
First make sure that the TV is switched on and is switched to the HDMI input to which the Q box is connected.
Then with the Q box switched on with green led illuminated
Press
Home 1 0 8 0 Home
on the Q box remote control.
This will change the Q box to standard resolution which will work for all TV’s.
Avatar for Willo2
Thanks for the reply, I've tried that, no luck!
Hi @Willo2
Have you tried rebooting your Q box?
Avatar for Willo2
Hi @Willo2
This message was authored by: JonneyJR
I have the same problem with my Sky Q box connecting to my LG TV, tried everything, only two things work...
1. Turn off the Sky Q box from the mains and reboot it.
2. My preferred method, Switch on Sky Q box, if screen blank, change TV input to Live TV [antenna], then switch Sky box off/on from remote, it then kicks in.
