24 Sep 2023 02:33 PM - last edited: 30 Aug 2024 09:59 AM by KevNewMedia
Hi
Netflix is often not working on SkyQ. We have checked the Netlfix website and there are no problems with Netflix itself.
We rang up before and sky had directed us to the hidden menu to "refresh apps". However, the "Refresh apps" is no longer there, or perhaps moved?
We have Sky Broadband Ultrafast 1 (FTTP) and are getting good speeds.
Advice appreciated on what might be causing this issue, and where we can locate "Refresh apps".
Moderator note: subject of thread updated to better reflect the conversation
30 Aug 2024 08:29 AM
Posted by a Sky employeeHi Everyone
We want to thank everyone for their contribution and understanding whilst we continue to work through this problem.
You will find that the spinning circle will be replaced by the error message "Netflix has encountered an error. Code: tvq-st-102."
You will be able to clear the fault much quicker and easier than before, by selecting 'more details'
Followed by 'reset.' This will enable you to get back up and running much quicker.
We appreciate the time everyone has taken to provide the examples and no longer need you to fill in the form.
I'm marking this post as the answer, so that people can see this update without having to read the entire thread. This doesn't mean that the problem is fixed, however we've been able to implement the workaround into the message, to make things easier. When the problem is resolved, we will let everyone know.
05 Jun 2023 08:51 PM - last edited: 29 Nov 2023 02:47 PM by Daniel-F
Netflix will not load - keep buffering
Moderator comments: edited title
05 Jun 2023 09:10 PM
Assume you have tried rebooting your Q box @Teresa+SB
07 Jun 2023 10:39 AM
I have the circle going round when I try to access the Netflix app on the sky menu
07 Jun 2023 10:42 AM
Tried that
07 Jun 2023 11:23 AM
@Teresa+SB wrote:
Tried that
Hi @Teresa+SB
Have you tried refreshing the Apps in the Hidden menu.
Select Apps
then highlight Refresh all Apps on this box.
You'll see a message that says, 'Your apps are being refreshed'. This will stay on screen until you press Dismiss to return to normal viewing
It’s recommended waiting at least 5 minutes before doing so.
Refresh Apps can take up to 24 hrs to complete .
07 Jun 2023 06:55 PM
We had sky fibre fitted on Monday we cannot connect to apps on tv or the hive and Alexa
26 Jun 2023 08:54 PM
Netflix app not working on Sky Q box. One day it loads, the next day it doesn't. Now it seems to be completely defunct. I've tried Sky box on/off, updating Sky box, 0,0,1 on settings and apps refresh, everything that has been prescribed as a fix. Now assuming that there is either an inherent issue with Netflix app on Sky Q experienced by many, or my Sky Q box is malfunctioning. Has anyone else managed a permanent fix? If I paid for Netflix subscription through Sky would this magically fix the issue? Just being sceptical 😛 thanks in advance.
27 Jun 2023 08:49 AM
Hi @Robin34 Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on to reboot?
29 Jun 2023 09:08 PM
Why, despite frequently resetting my sky box and updating my apps am I unable to access Netflix consistently through the sky box?
I have no problem accessing it on any other machine, but for well over six months now it is a lottery whether the Netflix app will load at all via the sky box. It just buffers endlessly and never loads, or sometimes it will take ten + minutes to load. Oftentimes we just give up.
This is not an issue with the internet. It is not an issue with Netflix. It is an issue solely happening through the sky box and never resolves when taking any of the advice this forum suggests.
sort it out sky this is ridiculous!
30 Jun 2023 08:56 AM
Hi @Vimes123 Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on to reboot?
01 Jul 2023 12:38 AM
Hi, yes I've already tried that several times. It doesn't make any difference.
01 Jul 2023 08:38 AM
@Vimes123 Try:-
Refresh Apps:
And if any of the steps don't help you can also Reset Settings:
11 Jul 2023 07:53 PM
Thanks @Quoman7. The Netflix app has been working on SkyQ the past few weeks, but again decided to stop loading yesterday and today. So I took your advice and turned off router and sky box and reloaded it all. Worked a treat! If it requires this level of rebooting every couple of weeks I can live with it. But if it starts playing up frequently like it did before, sad times. For now, your advice has worked so thank you. Kind regards.
15 Jul 2023 08:08 PM
I've tried this and Netflix still won't load. I've turned everything off and unplugged to but nothing helps
