16
This discussion topic has been answered Discussion topic: My Sky Q box doesn’t have an R for record
This message was authored by: RoseS45
Should all SKY Q customers be able to record. If so, how do I record from my remote as it doesn't have an R? Thanks!
This message was authored by: Doc5907 Answer
Re: My Sky Q box doesn’t have an R for record
@RoseS45that is a Glass/stream remote which doesn't have a record function. Are you sure you have Sky Q?
Sky Q 1TB UHD
LG TV
Sky Mobile
Hi @RoseS45
14 is the record button
@RoseS45  all sky Q remotes have a record button, it being the red button. See below..
If yours doesn't, please attach a photo.
Sky Q 1TB UHD
LG TV
Sky Mobile
Avatar for RoseS45
Level 0 icon
Sky Q 1TB UHD
LG TV
Sky Mobile
Avatar for RoseS45
Level 0 icon
That's the remote I received - can't see an R?!
@RoseS45Looks like they sent you the wrong remote. Was it a replacement ?
Just to be sure, could you please post a picture of your Sky box.
Sky Q 1TB UHD
LG TV
Sky Mobile
This message was authored by: GillianK
I have same remote control how do I record on it
@GillianK if you have Sky Q then that is the wrong remote that is a Sky Glass remote and wont work for recording on Sky Q you will need to get a Sky Q remote
@GillianK  Do you have Sky Q or Sky Stream?   Can you post  apicture of the box you have?
This message was authored by: SophieMannion
Hello
my nan has recently got sky however the remote doesnt have R button, could she request for remote control that does have Record button on it as she doesnt really use apps etc
@SophieMannion wrote:
Hello
hi @SophieMannion
Does your Nan have a SKY Q box which is connected to a Satellite dish via 2 cables (or 1 if using a communal Feed) or just a small box called SKY Stream that connects to wifi/the internet ?
It connects to satellite dish
Strange that she doesn't have a record button - can you check Posts 3 & 4 on this discussion & confirm which the remote looks likes
She got remote control same as post 4
Answered - Go to Answer
