Discussion topic: How do i connect a replacement TV to Sky Q main box via WiFi ?
Message posted on 02 Dec 2023 06:02 PM
Old TV was set up by Sky engineer when we had Sky Q installed. replaced the TV but cant connect to the SKy q main box via WiFi. Internet is working fine as other tvs are connecting to Sky q and the new TV is picking up Netflix etc
Message posted on 02 Dec 2023 06:08 PM - last edited: 02 Dec 2023 06:09 PM
Re: How do i connect a replacement TV to Sky Q main box via WiFi ?
The TV doesn't connect to SKY Q via wifi as such.
Although if you have SKY as your internet provider the SKY Q box does form part of the SKY Q mesh (just another access point for your wifi). but you say the TV is picking up Netflix so I am guessing it has connected OK to your home wifi
For TV it must be connected via an HDMI cable.
Message posted on 02 Dec 2023 06:11 PM
Many thanks
