7
This discussion topic has been answered Discussion topic: Multiroom - cost for extra rooms
This message was authored by: Clara56
I pay for multiroom subscription so my child can watch their programmes from a different room to our main tv. If I decide to pay to have another SkyQ mini box fitted in a third room, will my multiroom subscription double in cost or do I just pay for the SkyQ mini box to be fitted in an extra room?
Re: Multiroom - cost for extra rooms
@Clara56 wrote:
Thank you that has been really helpful.
My hardware version says 32Bxxx so I am guessing this means we will be able to purchase another SKYQ mini as this will bring our total mini boxes to two.
@Clara56
You will be able to loan another mini box.
@Clara56
Sky will loan you a maximum of 4 mini boxes. You can watch Sky content on two minis and the main box at the same time. You may be able to use a third mini box if the first one in use is being used for a streaming app ie: Disney+. That limit does not change if the main Sky Q box is not being viewed. Remember that UHD content can’t be viewed on a mini box.
The original 1TB (non-UHD) Sky Q box only allows one mini to be in use. To check if you have the non UHD 1TB box check in:-
If it shows as 32Cxxx then you have a non UHD 1TB that only supports 1 active mini box.
All 2TBs and the UHD/HDR 1TB permit two mini boxes. Each mini box which is loaned to you may be subject to a one off upfront charge but you only need one monthly Multiscreen subscription.
@Clara56
The Multiscreen subscription you are already paying will cover up to four Mini boxes, of which any two can be in use simultaneously (assuming you have a main Q box which can support that)
Avatar for Clara56
Level 0 icon
Thanks again
@Clara56
Avatar for Clara56
Level 0 icon
I do have a Q Box yes, we replaced a really old box a couple of years ago. In fact the techician who came to set it all up for me said my old box belonged in a museum! LOL!
Avatar for Clara56
Level 0 icon
Apologies, I clicked the answer button in error. You have very kindly answered my query
@Clara56
Glad to be of help.
