Discussion topic: Mini box cannot find SkyQ box
Message posted on 01 Oct 2026 12:03 PM
My mini box has just started saying it can't find Sky Q box.. On Q box all 4 systems ticked. Turned QBox off and on and still mini box not finding Q box. Front of Q box shows a red light and a green light
Message posted on 01 Oct 2026 12:36 PM
Re: Mini box cannot find SkyQ box
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
