Discussion topic: Disconnection problems
Message posted on 30 Sep 2026 07:59 PM
My sky Q box keeps disconnecting from WiFi even though there is no problem with my internet. I am getting good download speeds and my signal is not dropping. I have a sky hub connected to my router. I can watch tv but not apps, it keeps saying there is no network connection
Message posted on 30 Sep 2026 08:05 PM
Re: Disconnection problems
Hi @PRA14
On Sky broadband hold the Reset on the back of the router until the power light flashes green (about 10 seconds). Don't unplug or switch off your router while it resets. The power light will go green when it's done.
If your router does not have a reset button, reboot it by disconnecting the power lead for 30 secs and then reconnecting.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
On Sky Broadband you will be asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky or Sky Max Router) then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
Message posted on 30 Sep 2026 09:18 PM
I have the same issue
Message posted on 30 Sep 2026 11:30 PM
Why...thats ridiculous surly
Message posted on 01 Oct 2026 04:53 AM
@weezel wrote:Why...thats ridiculous surly
"Surely". Surly is something I am when getting up at 0430 to go to work 🙂
I assume you're referring to oldfella's bold section above? It's because the latest sky routers no longer have the proprietary software on-board which was used (unwisely in my opinion) to create the non-standard Q mesh.
Message posted on 01 Oct 2026 02:14 PM
I did change it as though it was a third party router and still lost connection to q
