Discussion topic: Multiple issues on SkyQ box
This message was authored by: Rob+Mab
My main Sky Q box appears to be faulty.
The issue started with recordings freezing and stuttering during playback. It then began affecting live TV as well, with messages saying: “There is a technical fault with this channel. Please try again later.”
The box has also become very slow and unresponsive. At times it will not change channel at all, and the on-screen preview window has gone black. I have already power-cycled the box by switching it off at the mains and restarting it, but the problem keeps returning.
At the moment the fault appears intermittent, but it is continuing to recur.
HOW do I book an engineer or get a replacement box please ?
This message was authored by: Me134
Re: Multiple issues on SkyQ box
Check the answer given by Lettice here:-
https://helpforum.sky.com/t5/Sky-Q/Broken-Sky-Q-box/td-p/4866343
Take especial note of the advice to remove the viewing card and to have the old box ready for the doorstep swap.
Not a Sky employee
Sky FTTP 500Mb to Max Hub (WiFi disabled)
Pair of TP-Link Deco BE65's in AP mode used for WiFi access with MLO enabled, main Deco hardwired to Max hub
@Rob+Mab
Try the troubleshooting on this link.
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
This message was authored by: Harsh75
After an hour my SkyQ box restarts itself and turns the TV off too. It restated both Q and TV but a few times both shutdown. I think there is a fault with SkQ box. Please advise
@Harsh75 wrote:
Please advise
Yes, sounds like a fault with your box.
