12
This discussion topic has been answered Discussion topic: Moving home
This message was authored by: leanne108
Moving home
So i get the keys to my new house on monday 19th aug now i rang sky to sort move date out ect so i can take it with me to be told the house isnt reg registered and I would have to do this first, but it's not a new build. It's an old house so I don't understand why it's not registered. Can someone please help me with this?
This message was authored by: MightyQuinn Answer
Re: Moving home
Hi @leanne108   Is it on the Royal Mail database? If not, that is the first thing you need to sort out.
Re: Moving home
What services do you have?  As an aside you need to give 2-4 weeks notice...
https://www.sky.com/moving-home
Re: Moving home
Avatar for leanne108
Re: Moving home
When you put post code in with Royal Mail it comes up so unsure why the house isn't registered it was built 1910s
Re: Moving home
He never said I have to give notice and I have phone line internet sky q and mobile phone with sky iv been with them 16 year and never had problems
Re: Moving home
Sure, but you are at the mercy of available OpenReach and Sky engineers - the likelihood of being available on 19th is close to zero.
Re: Moving home
I'd contact them again - it may well be they've mistyped the postcode on their system.
Re: Moving home
Take all the equipment with you.  The mobile phone will be fine - only the account address needs updating.
As noted, OpenReach will need to provision the service and a Sky engineer will need to erect a new dish (if required) and connect and test.
Re: Moving home
I don't want them out on the 19th I just want to book them in while I'm off work moving house
Re: Moving home
Ok, sure - you'll have to see what slots they have (once they get past the address issue).
Re: Moving home
I thought they had to disconnect you and then move it to the new property
Re: Moving home
No... You can remove and unscrew all the cables from the Q box and router.  (You leave the dish behind)
IF the new property has a dish already then it may work as-is.  But for the phone/Internet there's a provisioning step required to enable the line.  (Or even cabling work required to the property if there's no existing line)
Re: Moving home
Thank you for your help
