9
This discussion topic has been answered Discussion topic: Minute text on sky q.
This message was authored by: Kitte
Hi
i have recently changed from a 39" tv to a 32", 40" being too big for my room and 39" are no longer made. I now find, that the programme guide is impossible to read, subtitles as well, but there is no provision  on SkyQ to alter the size of the text.
I find this most annoying and Sky obviously don't care about elderly people with poorer eye sight.
This message was authored by: nigea99 Answer
Re: Minute text on sky q.
@Kitte wrote:
Hi@Superuser
I definitely have the high contrast on as well as having moved the tv closer to where I sit.
The biggest problem is the EPG to be fair, so I will have to buy a tv magazine I guess !
The configuration of my  lounge and furniture prevents me from having anything bigger, the difference in width was 10cm and the feet would not have fitted on my corner tv stand.
hi @Kitte
With the most recent Software update you can now increase the size of the EPG
Unfortunately I think it is limited the EPG and maybe a coupe of other places
Go to Home - Settings - Accessibility - Screen Magnifier
Hi @Kitte
 I suppose sitting closer to the TV is your only option. How about the high contrast setting for the TV Guide Home -> Settings -> Accessibility -> High contrast to see if that helps.
https://www.sky.com/help/articles/accessibility-information-sky-mobile-broadband-and-talk-customers
You should note that modern 40" TVs are generally smaller than old 39" TVs as the bezel (edge) is considerably smaller.
Avatar for Kitte
Hi@Superuser
@Kitte wrote:
Hi@Superuser
hi @Kitte
Avatar for Kitte
No such thing as screen magnifier under accessibility on Sky Q !!!!
I guess it is possible that the latest release (Q270) has not reached your box yet.
I am not too sure if it is availble for manual download:
To  refresh  follow the  first few steps on this link
Software update
@nigea99
I'm not sure the rollout has started yet.
This message was authored by: adizz
I have updated the magnification and it works!  I am sight impaired and can now read the guide from my chair and the picture is also sharper and deeper colour.
Avatar for Kitte
Hi, I have got the updated version now too, but it is far too large for me. I was expecting  to be able to select a size that suited me. I need to be able to see a section of the guide at a glance, not just a few letters. Maybe your need is greater than mine ?
@Kitte
That is the option being offered. If I remember correctly it is 150%. There's no in between setting.
Answered - Go to Answer
