Discussion topic: Sky box
Message posted on ‎25 Jul 2024 08:36 AM
Sky box
My sky Q box won't switch on, we've tried all the connections but it just seems to be dead
Message posted on ‎25 Jul 2024 09:49 AM
Re: Sky box
Is the power LED illuminated on the front panel? Red, amber or green?
Message posted on ‎25 Jul 2024 09:59 AM
Re: Sky box
Hi @Ursula4
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
Message posted on ‎25 Jul 2024 10:55 AM
Re: Sky box
It's been sorted by a technician but thank you. Looks like the kids managed to reboot to factory settings
