Discussion topic: Mini box showing different network name to the router and main box
This message was authored by: Jules19
The network name on the router and the main Q box is not the same as the mini box is showing. The mini box is stating it's connected to the Q box and the network but all channels saying "technical fault"
Avatar for Jules19
Re: Mini box showing different network name to the router and main box
To add: I have reset both boxes and the router with no effect.
Hi @Jules19
when you say reset both boxes
what reset have you carried out??
Avatar for Jules19
Both boxes have been turned off and restarted. Also carried out a network reset this morning but still showing a different Sky network name to the main box
Hi @Jules19
This is not unusual if you are on 3rd party broadband.  In this instance the main Q box may show your Router SSID.
Minis  will always show a Sky SSID for the main Q box Sky mesh WiFi.
Avatar for Jules19
I am on Sky broadband.
Hi @Jules19
Do you have the new Sky max router and WiFi pods?
Avatar for Jules19
Avatar for Jules19
We only switched to Sky about 6 weeks ago but it was all working well when initially set up. Mum in law is in an annexe attached to our house. There is a Sky WiFi booster in her lounge
Avatar for Jules19
Also my sons mini box says the same network as the main box. His is working fine
Ok @Jules19
That looks like the Sky Hub not the Max.
Try a complete reset of your Q connection.
On Sky broadband hold the Reset on the back of the router until the power light flashes green (about 10 seconds). Don't unplug or switch off your router while it resets. The power light will go green when it's done.
On Sky Broadband you will be asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button.
Once the main Q box is back up and fully running reboot your Q mini.
To reboot press Standby on your mini remote (if the box responds to the remote), and then switch off and unplug at the mains.
Wait at least 30 secs and then Plug back in and switch your mini box back on at the mains.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait for 30 secs before you press Home on your mini remote or if this is not working press the standby button on the front of the Q box (Amber led)
Edit
You have posted additional info on the mini.
If the mini is connected to the Sky Q WiFi booster
You need to first check that the booster is connected by WPS to the main Q box or router if nearer.
Then the network rest on the mini needs to connect by WPS to the booster
Avatar for Jules19
Ok. Thank you. I will try that later once my son does not need the WiFi. Thank you for your help
Avatar for Jules19
@oldfella   thank you. I successfully got the right WiFi showing by using the wps button on the sky booster. Unfortunately it hasn't fixed the technical fault message. But I now know that wasn't the issue. Thank you for your help
