Discussion topic: Mini box keeps freezing or losing signal
This message was authored by: Nic6
This has been going on for a few weeks now but seems to be getting progreworse wheneatching live tv. Sometime the signal is disrupted but usually we geta blue screen and the following message "You can't currently watch TV as there's issue with the connection between this mini box and your sky Q box. For help press?" Is this a fault with the mini box or sky Q box?  Our wifi is fine so this is not an issue. We have  recently struggled to play Netflix through our Sky Q box - don't know if this is a coincidence or not!  Thanks
Re: Mini box keeps freezing or losing signal
Hi @Nic6
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box.
Avatar for Nic6
Thanks. i should have said we are having to  reboot both devices to try and solve the issue. That works for. A short period but then it happens again. We have no problems with using wifi in the room where the mini box is located and the wifi is near the Sky Q box. We don't have sky wifi.
Hi @Nic6
If you are not using Sky Broadband then your WiFi network is irrelevant as the Mini will need to connect to the Main Q box WiFi.
Did you carry out a Network reset onthe mini as per my previous post?
ie
Avatar for Nic6
Thank you. It appears to have improved. Only time will tell but thank you for your help
This message was authored by: Rachel-M
I am also having the same issues and have tried all of the above and it is just getting worse, no signal problems with anything else in the house and not using sky for broadband, losing the will to live with it at the minute as I can't seem to be able to watch any of my recordings as it just says they are no longer available or I get a blank blue screen and nothing happens, tv guide won't fully load and if try to just watch something it cuts off every few minutes and says it's having connection issues but the settings show everything is connected! I'm wondering if the box is just knackered and I need a new one
This message was authored by: macker51
My mini boxes in both the bedroom and tv room keep crashing .Sometimes up to 10 times a day and usually from 10pm at night they don't work at all .Always says the same thing we cannot connect to your broadband router .The wifi is working fine with smart tv so I can watch Netflix and Disney on that but not through sky
This message was authored by: jct
I'm having the same problem. I had a sky booster installed and no help. Also have tried using Ethernet and develop to try to hardwire the mini boxes but to no avail. I've had the BT wifi upgraded if newest router and wifi is fine through out the house. It's intermittent but happens daily, different times. I've looked at the channels used and both wifi and sky seem to use Chanel 36, so maybe channel conflict?
This message was authored by: andyfromt-town
Same here. Have tried all the trouble shooting suggestions but sky mini box seems to be progressively worse! Any other suggestions??
This message was authored by: Tams82
Exactly the same is happening to us. It's with the sky q box. It will work okay for a little while and then the screen freezes. The problem is getting worse and worse. Sky have replaced the sky box and router but the problem is still there. Hours and hours spent on the phone and waiting for sky engineers and no resolution. Don't know what more I can do. So upsetting
This message was authored by: Skinner1110
Try deleting some of your recordings, and deleting them permanently.
This message was authored by: LR1984
I'm getting this. Also when I try to fast forward through a program on the mini box, it either doesn't do it or it fast forwards and then won't stop, no matter what I press on the remote. The main box has no problem and there's no problem with the one in my son's room, it's just the one in my room.
I'd like a new one really but I've been told Sky will just send someone out. As its intermittent, I can't guarantee it will happen when an engineer arrives!
I've reset the box many times and reconnected it etc. Nothing is working.
@LR1984 that can be that the mini box is at the limit for receiving the signal from the main box, so by sending an engineer they can check the stregnth of the signal and if need be add a booster midway between the boxes if they decide that its a faulty box then they can replace it
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
I already have a Sky booster and have fibre to the house.
This message was authored by: Alpha123456789
Same exact problem for me, started about a week ago after years of working fine. This is obviously something sky has done!
