Discussion topic: Sky box keeps turning off
Message posted on 25 Nov 2025 06:37 PM
My sky Q 2TB box keeps turning off, even after changing the box for a replacement, connecting to a new TV, the box will completely turn off (not standby) and requires me to go through the whole boot up process.
Message posted on 25 Nov 2025 07:39 PM
Re: Sky box keeps turning off
Hi @burtytoon
First make sure that the Q box is on the latest software.
https://www.sky.com/help/articles/sky-software-updates
Then when or if it is carry out a Reset Settings in the Q box hidden menu.
