Discussion topic: Majority soundbar
Message posted on 29 Aug 2023 10:06 PM
Majority soundbar
Control my volume using the sky remote
Message posted on 29 Aug 2023 10:14 PM
Re: Majority soundbar
Unlikely to have any native profile. Best chance will be via HDMI CEC by controlling the TV.
Message posted on 29 Aug 2023 10:21 PM
There is no hdmi on the soundbar.
I have connected a audio digital cable into my samsung tv to my soundbar.
It works but the sky remote doesnt control the volume...annoying
Message posted on 29 Aug 2023 10:52 PM
@Freck+k wrote:There is no hdmi on the soundbar.
I think they need to talk to Sky to get included in the built-in IR profiles.
Message posted on 30 Aug 2023 07:45 AM
Without an HDMI input you won't be able to directly control the soundbar volume. That is not a Sky issue, it's the failure of the soundbar design
Message posted on 25 Jan 2024 11:48 AM
I have been controlling my Majority soundbar's volume with my Sky Q remote for the past 1 1/2 years quite successfully.Up until 2 days ago when I changed TVs.The s/bar is connected via Toslink (fibre optic) cable.So it IS possible to connect without using HDMI.I just dont know what code I used to do it back then.
Message posted on 25 Jan 2024 12:18 PM
Just for the record,after a bit of perseverance I now can control my Majority K2 soundbar volume using my Sky Q remote via Toslink. Using one of the Magnavox settings on the menu,I'm not sure which,all is well.So,all the experts who say it is not possible are wrong.WRONG.It is possible.Just a bit of patience is all thats needed.
Message posted on 25 Jan 2024 12:21 PM
That is wrong information.It is possible using a Toslink connection.I've done it.@Invisblename
Message posted on 25 Jan 2024 12:35 PM - last edited: 25 Jan 2024 12:35 PM
@radiolistener wrote:That is wrong information.It is possible using a Toslink connection.I've done it. @Invisiblename
No you haven't.
You've found a code that sends a compatible IR signal. The TOSlink protocol does not have volume information.
Message posted on 25 Jan 2024 12:44 PM
Yeah.In other words I'm controlling the soundbar volume using my Sky Q remote,which,without using techtalk of any kind,is what I wanted to do.
Message posted on 25 Jan 2024 01:29 PM - last edited: 25 Jan 2024 01:30 PM
@radiolistener wrote:Yeah.In other words I'm controlling the soundbar volume using my Sky Q remote,which,without using techtalk of any kind,is what I wanted to do.
Sure, I'm happy for you. Not sure what the pop at 'experts' was about.
But it's nothing to do with TOSlink. The remote is sending a signal direct to the soundbar. Which, of course, if you find a compatible code then it will work.
Message posted on 25 Jan 2024 01:53 PM
OK going by what 'invisiblename' wrote (Without an HDMI input you won't be able to directly control the soundbar volume.) I took that to mean what it said.Maybe I misconstrued what they said but I found that to be untrue,I can directly control the soundbar volume......without HDMI.
Message posted on 25 Jan 2024 01:56 PM
@PandJ2020 I think the comment was aimed at the post that said
"Without an HDMI input you won't be able to directly control the soundbar volume. That is not a Sky issue, it's the failure of the soundbar design"
Which if you have the correct infra red remote code then you can directly control the sound volume on the sound bar with the Q remote
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 25 Jan 2024 02:11 PM - last edited: 25 Jan 2024 02:12 PM
@radiolistener wrote:OK going by what 'invisiblename' wrote (Without an HDMI input you won't be able to directly control the soundbar volume.) I took that to mean what it said.Maybe I misconstrued what they said but I found that to be untrue,I can directly control the soundbar volume......without HDMI.
...which was in addition to my post #2. (Stating that a native IR code may not be available - these send a signal directly to the soundbar)
The IR function is primarily for a TV*. Then the TV can send a volume request to a soundbar/amp via HDMI CEC - this cannot be done over TOSlink (which was the point made).
*some other devices are listed/work
Message posted on 25 Jan 2024 02:53 PM - last edited: 25 Jan 2024 03:00 PM
edited as not needed
