3
This discussion topic has been answered Discussion topic: Lost internet connection on Sky Q
This message was authored by: BarTug
Have lost Internet connection on main TV and via mini Q box. Have reset multiple times over past few days but it won't accept password despite it definitely being entered correctly. Can still get Sky on main TV but lost it on other TV upstairs via mini box. Can you help please?
This message was authored by: Quoman7 Answer
Re: Lost internet connection on Sky Q
Hi @BarTug Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on to reboot, then do the same with the Mini box?
@BarTug Who is your broadband supplier ?
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for BarTug
Many Thanks for your advice.
I disconnected and reconnected  BT router as you suggested and pleased to say it worked. So all's well again👍🎈
Answered - Go to Answer
