Discussion topic: Lost ITV1 HD
This message was authored by: Toptyke
Lost ITV1 HD
I've lost ITV1 HD (channel 103), either it is pixelated, frozen or the Sky Q box says there is a problem with the satellite system.  No other channels affected, no bad weather.
Re: Lost ITV1 HD
@Toptyke  Work through this link at the end there should be an option to book an engineer https://www.sky.com/help/home/sky-tv/sky-tv-q/fixing-sky-q/fixing-live-tv/no-satellite-signal/articl...
Re: Lost ITV1 HD
@Toptyke
A “no satellite signal” message relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
If you’re on a communal dish you’ll need to liaise with your landlord or building management company who will deal directly with their approved engineers.
Avatar for Toptyke
Re: Lost ITV1 HD
Thanks for your reply.  Having checked everything over and found no obvious cause I have booked an engineer.  Earliest I could get is 28th June!
