Discussion topic: Im having problems with my sky box and snini boxs
Message posted on 16 Jun 2024 10:25 AM
My sky q mini box's looses connection and the main box gas come up with hard drive problems
Message posted on 16 Jun 2024 10:37 AM
Re: Im having problems with my sky box and snini boxs
@ianmarie Have you tried the steps here https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Message posted on 16 Jun 2024 11:05 AM
If the HD is having issues then the mini's will fail (as the signal is buffered on the HD before sending to the mini).
A failed HD is usually fatal - follow the link above but a replacement box will likely be required. Remember to remove your viewing card when the box is swapped...
