Discussion topic: It says not programmed
This message was authored by: Ayaz
Tv installed yesterday is not working
Avatar for Ayaz
Tv box installed yesterday is not working
This message was authored by: Deedee36
Re: It says not programmed
@Ayaz  Did you have sky q installed yesterday? The not programmed message would suggest a tv issue is your q box switched on?
“Trying to help improve sky glass”
hi @Ayaz
Not programmed is a message from your TVs Freeview Tuner
Try Selecting an HDMI input on your TV (using either the TV remote or if it has been programmed the button on the top right of the SKY Remote with an arrow pointing into a screen outline)
Avatar for Ayaz
It says no signal
@Ayaz  No signal or no satellite signal? Are there any lights on the front of your q box??
Avatar for Ayaz
Yesterday it worked
Re: Tv box installed yesterday is not working
@Ayaz Have you tried rebooting your main Q box ie
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
@Ayaz  If you answer my previous question we may be able to help you
@Ayaz
We will need more information than 'not working' if you want some advice please.
edit: separate threads now merged.
Avatar for Ayaz
Re: Tv says Not Programmed
Tv is saying no connection
Avatar for Ayaz
No tv worked yesterday. This morning when I switched on it did not work
Avatar for Ayaz
Avatar for Ayaz
Have you got the picture ?
Avatar for Ayaz
The light on the box is red and White
