Discussion topic: It says not programmed
Message posted on 31 May 2023 04:30 PM
Tv installed yesterday is not working
Message posted on 31 May 2023 04:34 PM
Tv box installed yesterday is not working
Re: It says not programmed
@Ayaz Did you have sky q installed yesterday? The not programmed message would suggest a tv issue is your q box switched on?
“Trying to help improve sky glass”
Message posted on 31 May 2023 04:34 PM - last edited: 31 May 2023 04:35 PM
hi @Ayaz
Not programmed is a message from your TVs Freeview Tuner
Try Selecting an HDMI input on your TV (using either the TV remote or if it has been programmed the button on the top right of the SKY Remote with an arrow pointing into a screen outline)
Message posted on 31 May 2023 04:37 PM
It says no signal
Message posted on 31 May 2023 04:38 PM
@Ayaz No signal or no satellite signal? Are there any lights on the front of your q box??
Yesterday it worked
Message posted on 31 May 2023 04:39 PM
Re: Tv box installed yesterday is not working
@Ayaz Have you tried rebooting your main Q box ie
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
@Ayaz If you answer my previous question we may be able to help you
Message posted on 31 May 2023 04:39 PM - last edited: 31 May 2023 04:42 PM
We will need more information than 'not working' if you want some advice please.
edit: separate threads now merged.
Message posted on 31 May 2023 04:43 PM
Re: Tv says Not Programmed
Tv is saying no connection
Message posted on 31 May 2023 04:44 PM
No tv worked yesterday. This morning when I switched on it did not work
Message posted on 31 May 2023 04:45 PM
Message posted on 31 May 2023 04:48 PM
Have you got the picture ?
Message posted on 31 May 2023 04:50 PM
The light on the box is red and White
