Discussion topic: It says not programmed
Re: Tv says Not Programmed
@Ayaz
I have merged all your posts on the first discussion you raised - please make sure you only answer here
As the others have asked - are you sure your SKY Q box is on
Avatar for Ayaz
This message was authored by: Ayaz
Sky box light showing red and white lights
Avatar for Ayaz
Are you still checking
This message was authored by: Invisiblename
There is no "white" light on a Sky Q box! Can you confirm what lights are showing? Also, have you checked that your TV is set to the HDMI port that your Sky is plugged into?
I am just another Sky customer!
This message was authored by: Doc5907
Re: It says not programmed
Maybe its all the phones in front of your TV causing an issue !
But seriously... You need a green light on your Sky Q box to get a picture. On your Sky remote try pressing power button, sky button and then home button to see if the light turns green.
Sky Q 1TB UHD
LG TV
Sky Mobile
