Discussion topic: Bomaker soundbar - How do I get my sky q remote to work the volume?
This message was authored by: Creggansmummy
I've been given a secondhand Bomaker soundbar to use as our usual orbitsound soundbar stopped working after a power cut.  I have connected it using the optical cable ( HDMI is not an option with the age of the soundbar) I'd like to control the volume with my sky q remote . I previously linked the orbitsound one using the Phillips code but Bomaker just doesn't respond to any of the 48 options. Am I now going to have to use 2 remotes ?
Re: Bomaker soundbar - How do I get my sky q remote to work the volume?
Hi @Creggansmummy
Did you try the Category Other brands
during the remote setup ?
Avatar for Creggansmummy
@oldfella
I have just retried the 68 options on "other brands" but to no avail 😞
@oldfella
Would it make a difference if I attached the optical cable from Sky Q to soundbar as opposed to TV to soundbar ?
I tried it earlier and it didn't work but if you have any other ideas ?
Thank you
@oldfella
Looks like you are stuck with 2 remotes then @Creggansmummy
@oldfella
 I really dislike accepting defeat but this one has stumped me.
Hey ho there's worse things that I could be worrying about in life !
@oldfella
If the relevant codes are not in the Q remote database there is nothing you can do @Creggansmummy
