Discussion topic: Issues with Q box
This message was authored by: Lynne521
Issues with Q box
I need a telephone number in order to speak to someone from Sky regarding my Q box. It's got to the stage where we are having to switch it off and reset at least once a week otherwise either lipsync is way out on recordings or we cannot get the channels list up. We have had it for many years and want to enquire whether we can have a new one.
Thank you for any help you can give me. Lynne
Re: Issues with Q box
@Lynne521
If you end up having to call Sky you can call Sky free by dialling 150 from a Sky Talk landline or a Sky Mobile, otherwise you can use:
https://www.sky.com/help/home
UK customers: Scroll down and click on ‘Need more help’ and it provides a 0333 number.
ROI customers: change the flag in the bottom right corner of the link to the ROI flag then scroll down and click on ‘Need more help’ and it provides a 0818 number.
(The forum doesn’t allow us to type the numbers in full).
You will find that similar to calling other large companies the start will be automated which may also try to send you back to the forum. Stay on the line as long as possible and don’t hang up.
▪️I AM NOT A SKY EMPLOYEE ▪️
Avatar for Lynne521
Level 0 icon
Thank you, will try this.
Hi @Lynne521
If you haven't already it might be worth trying a Reset Settings in the Q box hidden menu.
It may bring more life into your Q box.
