Discussion topic: I have no sky apps on telly
This message was authored by: Dani3
I have no sky apps on my telly, I have tried to push was button and says error need a sky q booster, I did have apps on telly yesterday ?
Re: I have no sky apps on telly
Do you mean your Sky Q box, rsther than your tv? You could try restarting both your Sky Q box and your broadband router.
@Dani3 if @Mark39 suggestion does not work then you could try refreshing the apps in the engineers menu
To enter the engineers menu do the follow
press the home button then scroll down to setting and hi-light
do not press select/enter but press 001 then select this takes you into the engineers menu
scroll down to apps > refresh
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
It sounds like the wifi connection is down
are you sure you're hitting the wps button on the router when the sky Q box tells you to? It's not well labbeled and easily mistaken for the reset button.
Avatar for Dani3
I have tried to refresh and it says there was a problem refreshing apps. ?
