Discussion topic: I have no sky apps on telly
Message posted on 31 Jan 2025 05:00 PM
I have no sky apps on my telly, I have tried to push was button and says error need a sky q booster, I did have apps on telly yesterday ?
Message posted on 31 Jan 2025 05:09 PM - last edited: 31 Jan 2025 05:09 PM
Re: I have no sky apps on telly
Do you mean your Sky Q box, rsther than your tv? You could try restarting both your Sky Q box and your broadband router.
Message posted on 31 Jan 2025 05:49 PM
@Dani3 if @Mark39 suggestion does not work then you could try refreshing the apps in the engineers menu
To enter the engineers menu do the follow
press the home button then scroll down to setting and hi-light
do not press select/enter but press 001 then select this takes you into the engineers menu
scroll down to apps > refresh
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 01 Feb 2025 06:49 AM - last edited: 01 Feb 2025 06:50 AM
It sounds like the wifi connection is down
are you sure you're hitting the wps button on the router when the sky Q box tells you to? It's not well labbeled and easily mistaken for the reset button.
Message posted on 01 Feb 2025 08:24 PM
I have tried to refresh and it says there was a problem refreshing apps. ?
